Hold on let me think about this I have the oil mixture kind of high because engine is new, so that maybe what is doing it also I will wait untill I go to 5 oz a gallon and if still does it worry, also, I can't have a air leak I sealed where the carb onto intake with HI temp RTV.
The mix should not make that much difference. I dont like the carb that comes with these things. I would check the float level, make the tabs hold the float just at the seam for the bowl. Check the main jet that it is not plugged with something. I have had to mess with every carb I have gotten, would be nice for one to work with no fuss. I drill a .040 hole in the direction of the air flow from the float area, makes them idle like a Yamaha, there is a post about that. Have fun Dave
PS: Make sure the carb is all the way slid on, the weld gets in the way, if so you will need a file, I use a O ring in carb throat to seat on.
I saw that post on drilling the .040 hole in the carb and did it and mannnnn it made sooo much difference. I too have the carb/intake oringed, no rtv. I guess it is possible that if there is way too much oil to fuel then it might need less air to run, but I would still look for an air leak.
Anyhow I think there obviously is some flaw in China......
QUOTE]
Yeah, it's called "No quality control".
Please point me to the post...and how hard was it to do, and what's the benefit?
Have you cleaned up your ports and gaskets yet? I think I'm going to do a bunch of work on the carb this week after what I'm reading...
Thanks,
Mark
