Shika_Usstan
I recently bought a Skyhawk 40cc motor (the only ones that are legal in Idaho as a cop was so nice to yell at me when riding an 66cc). I got it all set up and took it for a test drive. When the clutch is down the motor can run fine and when I'm not sitting on the bike and have the rear wheel lifted up it runs fine. But when I release the clutch while riding the motor instantly stops. It doesn't matter how fast I'm going the motor slows down and stops turning over.
Well based on previous knowledge I checked the engine head and all 4 bolts are tight and nothing is leaking out there. The Spark plug is tight and nothing is leaking out there either. Experience stands to reason is that it does not have enough compression. But even with just a 145 lb person a 40cc motor should be able to handle it. I don't know where it is losing the compression from. At first I thought it was a fuel line problem because when the throttle was pulled it would die because it would take in a lot of air but no gas. But I fixed that problem and now this one has began.
If anyone could shed some ideas on to how to fix it please let me know!
