I am a slime hater! I use the HD Slime tubes with pre filled goo in them and I can feel my tire hop up and down at about 17 mph... it gets a bit worse through 35mph.  its the spot of goo that lumps up and is held their but centripetal force.    I usually have to let the goo warm up and stop when I think the glob is at the top then let it coat the inside somewhat evenly then ride again and try not to stop.   it actually is a problem on my cruiser.. no suspension makes you feel every wobble and hop.  I think goatheder cant feel it cause of all that travel!  I think the beads will lump up the same way if their are too many...   seriously folks   a bike tire is so light that .5 oz is usually all they take...    I did one at my work on the balancer!   and even less if you take the time to true the wheel!!
 You said you use preslimed tubes...17mph pft
Funny preslimed tubes don't work! They have just enough of the product to coat the tube'''IF'' that. Then a guy sits there convinced he is going to use a patch IMHO thats very sad when folks can't figure this part out. Theres  Mebbe one/two ounce's in there if that!  I use up to  8 to 12 per tube but  I always run the likes of balloon size tires.. . Its having an active puddle in the tube that delivers the sealing agents and I dare say balances my tires. Thats my trick..Pretty simple
 Maintaining  perfectly straight rim's and tires   is absolutely something I have always taken  great  pride in..
I can ride in the gutter or the street to know the difference and not all of my bikes are state of the art full sus or have been . I have used this stuff for over 40 years and have never had a balance problem to diagnose  ..Fact is for me  I have yet to see it set up like you mentioned ether. I gotta suppose I have not seen everything in life we all learn new things all the time. I don't see enough weight or inertia here to explain this. LAMO
There is barely enough inertia with the Dynabeads.
			This is there reply,
THANK YOU,
CAROL
DYNA BEADS
(TEL)585-467-6028
(FAX)585-336-9397
DynaBeads
Bicycles do not go fast enough to balance. With a large diameter wheel you would not have to balance them unless your speed was in excess of 40 MPH or more. You could use 1 ounce and try it but I do not thing you will notice anything.
So , I dont know what to say. Since i already spent the $11 , I will probably try them out, but, who knows?..
Just not really sold on that story is all. I cleaned up a back yard this summer for somebody there was a ''new'' unused bottle mixed in with a whole mess of tools and other things that had scaled up rusted up a lot here in the desert. The stuff had not set up and looked perfectly fine. It was estimated that it was buried in that mess for mebbe 10 years..talking summer and winter. We put it in the wheel barrel tire we were using.
  I have had it dry up from trillions of goathead stickers and simply put more in the tube and or started over. What do I mean by this? The active puddle was gone and I was finally periodically having to reharden a tire with more air. Happens to me about every 3000 to 4000 miles. The bike tire is wasted after that anyway..  Never did I have a said lump or a balance problem to diagnose. Its just not possible to get a lump from a preslimed tube as there is nothing in there to begin with as I perceive it.. Think about it for a second how did they get a tube and a whole bottle of slime in that tiny cardboard  box.. It has always been like this they don't..I absolutely hate preslimed tubes.
Some  hard core spandex weight wienies tease this equation and never figure it out.. I will not ever use those little bitty skinny tires. There needs to be an active puddle and air volume in the equitation as I perceive it. Paper thin tubes are no bueno and real motorcycles don't use them.
There is such a thing as a tire that is out of round what this means is you are not going to balance it no matter what. If you have a ''hopping'' tire at an extremely  slow pace as '''''17 mph''''' it is way more serious than that in all of my years of hands on experience with this stuff. . I would be looking at things diligently for more accurate explanation IMHO.   A tank slapping hop at 17 mph is ridiculous.
Any way the thread seams to be titled  Dynabeads I guess and not about slime dunno? Never wanted to step on any toes.. Yet in my experience no flats and things have always  worked flawlessly on every bike I ever owned that is all.
Here where I live you would need a tire liner made of sheet metal to survive with out it and I would still get a sticker through the side wall. Yep I have found them there.
One rear tire of mine this summer got Pyracantha thorns, two small nails a shard of wire, last a whole barrage of goatheads. It made it 3000 miles and never went flat but I had to add air to it periodically. . I ride ''every day''  I put that old tube in a new tire after pulling the impalements off of it added more slime to it. ''don't even''' own a patch kit. Its been 15 gallons of gas I think since then by now. I added air to it one time it was 40 degrees outside was why.. It is rock hard as I type.   I have spent my whole life on bicycles. I have a real Mountain here I have  ran down the paved side of too.
