thegasbikeexpert
i would usee something foamy to help if you dont have the  right tools to fix the problem
Yeh holding your empty tank in your hand with two broken studs as I putt by!Kip.You use a real thin piece of rubber..My bike does 40+ mph and the tank has never moved. See you in the slow lane.
 Na, but really get a die at most any tool supply place and chase the threads. 4mm I think, 3 bucks or so. I also use an old tube as a pad to cover the space from tank to frame. Aircraft nuts are a safe choice also.
I use double sided foam tape made for insulation , about a 1/4" thick ...i tighten the tank till the straps just bend a little... the tanks stay put but you can move them if you grab the cap push side to side....worked good till just yesterday...got a call from a guy that bought a bike a week ago, said tank was leaking.... he drove 40 miles to my place and i gave him a new one... he had tightened it because "you could move it with your hand" .... same guy called three days ago with a broken stud in the intake manifold.....i see a pattern developing here..... if you are kinda new to engines just remember a drop of locktite( or squeeze the exposed threads a little with your pliers to prevent losing a nut on the road) and just good and snug is all it takes.... read bairdco's posts about motor mounts, he has it right.... i have had no problems with "cheap chinese parts or hardware yet....just overzealous mechanics.....
