Does anyone here run their engine without an exhaust pipe?
CrimsonPrince
77
17
8
28
Jus wondering if anyone here just lets their engine run without an exhaust pipe or a very tiny exhaust pipe that basically prevents rocks and debris from falling into the piston chamber....
Loop
127
77
28
49
S.Knoxville
The lack of an exhaust as I understand causes the engine to overheat as the pipe takes the hot gas away from the engine. This is why later on cox put little exhaust boxes on the higher end .049’s and actual exhaust pipes on the bigger “bees”
CrimsonPrince
77
17
8
28
Would an exhaust box work if I welded it into on a pipe that was then affixed to the cylinder outlet?
Loop
127
77
28
49
S.Knoxville
It should, a weed eater doesn’t have much more than that, you just need a way to get hit gas away and provide a bit of pressure.
