drive over and bring it back???
NO it wouldn't. You can ALWAYS over volt , not "overamp" - which is happening when using 48v motor with 36 V pack. For the gazilionth time : Volt = speed , Amps = acceleration (torque).Pardon me if this question has an obvious answer, but would a motor rated at 48V produce similar speed and torque at 36V as a motor rated at 24 to 36V? Just thinking if I do buy a new motor that I might get something that can handle a battery upgrade at a future date. You know; when lifepo4 batteries come on sale at dollarama
So buy 36 V motor - you can add more Volts later (faster , better range).
There were instructions weren't they (about controller , I mean)? Controller can be fixed (for example , by TV repair guy) and your "learning curve" has just gone waaay up I've messed up few things in my life too (and that was the stuff I know about), if that makes you feel better. As the bumper sticker says : S..t happens !
Watch out on the amp rating of the on/off switch (lamp switch isn't for the job, it could melt).
As for the repairs of the controller, I just mentioned one option out of top of my mind. Anyone who deals with electronics can repair it (unless leads on the circuit board had it), simply by replacing burnt components by the same/similar ones or upgrading it for right voltage (36 V). If it is just replacing components it shouldn't be expensive, but , bare in mind, more elaborate work could be more expensive than controller (you'll just have to check it out). Hope that "malfunction" can be solved.![]()
