perichbrothers
Cool dule -
Also if you set up all those FG sheet"facets" of the tank from the outside,
(the form is good to make cardboard templates over)
using masking tape or a hot glue gun with wood or whatever to make the shape,
you can use 1-2" strips of fiberglass from the inside to connect it together.
Then you trim with a razor blade and a light rasp file to clean off the sheet overlap,
then bondo up the edge, alot thicker and stronger.
(opposite of trying to get the edge to match the flat, which weakens that joint, and alot more grinding)
Talk to ya later.
TP
Talk to ya later.
TP
