Thanks Felix for your reply. I know you need the bearings with the neoprene seals, because you need to remove the one that faces inside the crankcase...your gas/fuel charge will lubricate it, it only makes sense to me to make these china motors as good as can be, even if left totally stock. I've heard people say they are throw aways, they last about a year and then they're done...I've had my motor for at least 5 years...it runs like a bat out of heck, but I did tons of things before i ever installed it in the frame. I made sure the flywheels on the çrank were noticeably bakanced, set the float level, it came set way too high. And I drilled holes inside my stock muffler, removeable silencer, to help exhaust exit in not such a restricted fashion. Ok, enough on that, I'll do a major search instead of trying the forum way out...ler you know what I find Felix
