deacon
minor bike philosopher
The only thing I can think of is the 24v current welded it shut.  Im going to see if i can run the switch on a lower voltage current.  If that doesn't work I will go back to the 20 amp house current switch that will hold it I know for sure.  But I knew in advance that the house current 15amp wouldn't but I also thought the switch circuit would be a low enough amps that it would weld it shut.  Nonetheless, I will see evidently the circuit did not make a difference or I wired it wrong but I don't see how I could.
Since the switch and the relays high amp side share the same battery input obviously for some reason they have the same amp running through them. I don't see how else it could happen. I would love to get it to run on 6v to make relay switch. That would make a small battery for the switch possible. however we shall see. I will probably wind up going back to the controller but I hate to. The on off switch runs with better power.
