cowboy1948
looking for some help here. did a search did not find any info on this. installed my engine. everything connected properly. removed clutch cover and small drive gear to install auto clutch. and I figured while I had this apart and no chain connected I would start it up it see how it runs. I had already installed a pull start. started it and it run great. just took slack out of throttle cables. and it was perfect. went to install auto clutch. went to put on the first clutch cover and it would not go on all the way over the clutch. surfaces were to far apart. looked around, found the clutch and drive sprocket shaft moved about 1/8'' back and fourth. so anyone. what 's the fix for this? any help. message me if you want to respond that way. thanks. looking for help.
