Clutch Removal
Tristan2021
Iowa
Ok so i tore down my 66cc china girl and i ported and polished it a little and then i took all 4 head studs out and locktited them in and i did the same with the exhaust and intake bolts but the reason i am on here is i CAN NOT get the big clutch gear/pad holder thing out since i am replacing the pads and gently lubing stuff up zpt
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Absolutely required tool for any serious HT motor work.
The other REQUIRED TOOL is a hand impact.
Make sure the puller is fully screwed into the threads with light oil and use light taps on the bolt once you tighten it with a soft hammer to pop the bond with the shaft and key.
Don't go gorilla wild and they work great.
I'm still using the first one I ever got in a kit.
