I was cursing all day the other day, slowly, to seat some new rings in a new cylinder and after a short stop, the clutch won't dis-engage. Ok, so I'll start with what I have already done so our posts don't get redundant. Checked the clutch cable adjustment, checked my camshaft which I pre-fabbed awhile ago out of a 1/4" ratchet breaker bar because the steel they use on the stock ones is garbage, checked the bucking bar, replaced my woodruff key on the small sprocket (had to be done due to earlier prob), checked to make sure clutch plate is moving and releasing from clutch pads, checked the "flower" nut and the bolt behind it to make sure it didn't come loose. And, with all that I still cannot get the engine to go into a neutral state of being so that it won't die at a stop sign. Any help here would be super groovy. Thx
Sorry, I guess i should mention that i have a Zeda 80 Firestorm that I have had for close to a year. I've done some work on it including 2 new upper half of the engine. The second just the other day. I'm hard on it, what can i say? The replaced cam shaft, a replaced throttle, replaced CDI and magneto, and this is the 2nd bike I've put her on.
