thats on the flats !!!!!!!!!!!!!!! no down hill it's registered on my speed --o it's a factClaims of this type of speed are taken with a LARGE handful of salt. 46mph? What's the source of proof? Or, as they say- "Downhill don't count."
So would you consider Spookytooth's guarantee of speed increase to be false advertising?:I would either stay at the 44T or go to a 40T at the smallest.
X2.......There`s always a give and take in that situation.....I learned that in motorcycle drag racing.....You can either be fast off the line and maybe run out of gear on the top or slow off the line and have some killer topend mph....I'm always amazed that with a hobby based on bicycles how often the fairly basic concept of gearing is misunderstood - given the assumption that at some point, someone might have actually pedaled while using gears
Picture trying to pedal from a dead stop up to 30mph using just first, then picture trying to pedal up to 30 from a dead stop using only your highest gear.
ANY single gear being a compromise between those two examples, bear in mind NO gear will provide any "extra" power - reduction in sprocket sizes only helpful for top speed if you're redlining anyway. While I wouldn't say Spooky's claim to be "false" advertising, there's simply way too many variables to give a concrete example. Weight, drag, environment, engine output (stock/modded), rim size, the list goes on....
The short story? Even if you've a shift kit - gearing is a fine-tuning experiment to get your engine in an RPM range you're comfortable with, relevant only to your bike, dependent on your performance specifics. Speed gains stem from the more involved engine performance, sprockets merely utilize that.
While you may see a increase in top speed by reducing sprocket size - you will pay the price in acceleration, there's no "free ride"
I'm new to this hobby but I've played with hp 2 strokes for a few years and while I don't claim to to be any kind of guru I do know some solid basics as fact and Bairdco is right with this post. I want to add to it though. First and foremost the Cycle must be sound, good lubed bearings, trued wheels and everything lined up. You can't possibly go fast if you have a bearing dragging or a sticky brake. DO NOT UNDERESTIMATE HOW MUCH FRICTION KILLS PERFORMANCE! Everyone goes straight for the motor but any good racer will tell you that horsepower won't do anything for you if it can't get it to the ground.porting helps a lot. on the intake, dremel out as much as you can to match the intake port on the engine. be careful not to go overboard. the engine port is bigger than the welds on the intake. while you're grinding away, get up inside of the intake manifold and smooth out the casting burrs.
the exhaust can get the same treatment, but again, there's not enough material to match the port exactly, so just do as much as you can.
pay attention to your spark plug's color till you get that dialed in.
make sure your bike's tuned up. good tires, straight wheels, no loose parts, greased bearings, etc. will help. the less rolling resistance that motor has to push, the faster it'll go.
as far as sprockets go, it depends on your weight and where you ride.
i'm 135 and i've got a 32 sprocket. works great on the flats, but bogs on steep hills. i can get an average of 37mph.
i had a 36 which worked great overall, and it averaged about 34.
nos and boost bottles are just gimmicks, don't waste your money. buy a tuned pipe instead. (haven't tried one myself, but everyone else swears by them.)
whenever you're adding a part, tuning something up, or modifying something, do it one piece at a time. that way you'll know what actually works for you and what doesn't. it'll also help you find problems. if you do ten mods at once and your bike stops running, you've got ten times the problems to figure out why.
despite what people say, don't expect much over 35mph, unless you're willing to spend money and tons of time fine tuning it. everyone likes to believe they're getting more out of their cheap little engine than they really are. (including me)
15mph and under...terrible with a 40T?40 tooth does me very well. Great for cruising around at 25 or maxing top speed of 35...
however going slow is terrible (15mph an under)
Yeah I saw that and thought the same thing. How is it terrible at anything under 15mph?! I for one find going 7mph the cut off on where it starts to get horrible on the stock 44t. I doubt the loss of 4 teeth double that speed.15mph and under...terrible with a 40T?
This is caused by one of three problems...you weigh 500lbs...you have a P.O.S. engine...you have fouled-up your engine and it is so out of tune that even the Chinese would laugh at it...
Jim
and it only costs some dremel time FTWporting helps a lot.
Nah I'm 205, and got a beach cruiser, and for me its real jerky around 13mph an under, comfortable cruising is at 25+ for meYeah I saw that and thought the same thing. How is it terrible at anything under 15mph?! I for one find going 7mph the cut off on where it starts to get horrible on the stock 44t. I doubt the loss of 4 teeth double that speed.
