Chain too tight
Discussion in 'Motorized Bicycle General Discussion' started by admhi, May 4, 2012.
  1. fx-2
    fx-2 New Member
    Oct 7, 2011
    125
    Start reading .There is every thing you want to know here . Go slow only one modification at a time . Have fun . Dan
  2. breno
    breno New Member
    Aug 19, 2010
    411
    i usually just cheat and cut the back mount a little thinner if I get stuck like that.
    I had the same problem the other day..Its like less than half a link too short but if you add 1 pidly link with an extra joiner the thing becomes rediculously too long!!
    just cut 5mm off the back mount which hugs the seat post and all is dandy.
    Stuff buying a half link if ya dont really need to.
    U dont even need to really cut 5mm off. Probly 2mm would do... could even do it with a simple file + a tub of elbow grease.
  3. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    Just remember when doing that, if you take 2mm of the mount then you gain 4mm in chain, 2mm from the top and 2mm from the bottom of the chain. It's the same if you add a spacer between the mount and the motor. If your chain is too long by 6mm then just add a 3mm spacer because it takes 3mm on both runs of the chain.
  4. breno
    breno New Member
    Aug 19, 2010
    411
    yeh thats roughly the logic I saw behind it too...
    You will also find the motor sits slightly lower in the frame giving a slightly different chain angle + ya need to make sure your exhaust isnt already very close from fouling anywhere as you may find it will touch the down tube just because you didnt check... on the other hand if you do check for this 1st, you will never run into problems as Murphys law states.
  5. Joel G.
    Joel G. New Member
    May 2, 2012
    16
    Re-mount the engine to possibly change length of chain needed or like the others said use a punch or strong nail but don't knock the link all the way out, just enough to get the chain end off. After that use a C-Clamp to put it back together. This is what I did anyway, and it worked.
  6. young grease monkey
    young grease monkey New Member
    Sep 20, 2011
    362
    For performance mods, the easiest one that gives a good bit of power is this thread: http://motorbicycling.com/showthread.php?t=16646. If you want to make it simple, just do the gasket trimming so they are flush with the ports and grind out the exhaust pipe so it lets more flow. And get the exhaust pipe from sickbikeparts.com, its the best bolt on power boost you can get.
