Chain too tight
Discussion in 'Motorized Bicycle General Discussion' started by admhi, May 4, 2012.
  1. admhi
    admhi New Member
    Apr 22, 2012
    11
    hello, recently i bought my engine from motorizedbicycle.ca, and i needed to take 8 links from my chain and still needed to take more, so i took more 2 links but now is to tight, i even can use the tensioner, it is any problem ? the chain will be looser when i start ride ?, i am trying to find another masterlink so i can put 1 link back, but aparently is hard to find the masterlink for the #415 chain., can i ride the bike with the chain tight or not ?
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    Put a couple links back in and use the tensioner.
    Better slightly loose than too tight.
  3. admhi
    admhi New Member
    Apr 22, 2012
    11
    actually when i took 8 linksstill soo long that even with the tensioner was good, so i took more 2 links, and i want put back more 1 link, but i dont have a extra masterlink, or i dont have any idea how to put back, i just cut the chain using a hammer and a punch, if i put the bolts back in a link and hammer it may works ?
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    Yes, you can put it back together by carefully putting the pin back in with a punch.
  5. Bikeguy Joe
    Jan 8, 2008
    11,529
    A lot of guys don't even use a master link. A chain breaker (tool) makes this work easier.
  6. admhi
    admhi New Member
    Apr 22, 2012
    11
    yeah i dont have a chain breaker tool, i just used a grinder and the hammer and the punch
  7. Bikeguy Joe
    Jan 8, 2008
    11,529
  8. fx-2
    fx-2 New Member
    Oct 7, 2011
    125
  9. admhi
    admhi New Member
    Apr 22, 2012
    11
    ok, today i will see if i can found the master link for #41,#415 or #42 i will bring a peace of chain to see if fits . if yes i will post on the forum about it, thanks for the help man, but you think if i start riding the chain will start loosing ?
  10. admhi
    admhi New Member
    Apr 22, 2012
    11
    my real problem that i dont want wait like a week to receive just a master link, i receive mmy engine on wednesday and i am so excited to put the engine to run ahhahaha
  11. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Typically the kit supplied #415 chains wear (stretch) quickly in the first few miles and need to be adjusted. Just take it slow and don't go for top speed until the chain starts to wear in a little.
    I'm assuming your chain/sprocket alignment is good. To get away with a chain that is a little too tight you'll need those sprockets exactly aligned.
    Good luck. Let us know how it goes.
  12. Bikeguy Joe
    Jan 8, 2008
    11,529
    I wouldn't run it with the chain too tight. You can damage the wheel bearings and also the countershaft bearing.
    Too tight is -0- freeplay. If you have at least a little bit of play you should be o.k. for now. It may loosen up a small amount, but better safe than sorry.
  13. admhi
    admhi New Member
    Apr 22, 2012
    11
    they are alingned but they was to tight that was a problem to take the master link off and open the chain, anyways i will give a look on a atv,bike store and tractor store if i dont find i will put the chain back and ride for few miles
  14. Bikeguy Joe
    Jan 8, 2008
    11,529
    Be careful, if it's real tight it may send your tensioner into the spokes....ouchy!
  15. admhi
    admhi New Member
    Apr 22, 2012
    11
    i cant put the tensioner haha, actually i can but is to tight .
  16. Bikeguy Joe
    Jan 8, 2008
    11,529
    Just be careful. I know how bad you want to take that ride, but BE CAREFUL.
  17. admhi
    admhi New Member
    Apr 22, 2012
    11
    yeah i am going to a bike,atv store and see if they have a master link or a chain breaker for sale
  18. fx-2
    fx-2 New Member
    Oct 7, 2011
    125
    Most hardware store carry drive chain and master links . Ace and true value if well stocked should have them . As was stated before if the chain not right don't ride it . Have fun . Dan
  19. Allen_Wrench
    Feb 6, 2010
    2,787
    I'm with them. Patience is a virtue. Impatience gets expensive. Wait until you can loosen the chain a bit before you ride.
  20. admhi
    admhi New Member
    Apr 22, 2012
    11
    i bought the master links, i bought a master link for the chain #415H and fits perfect, my bike is running now :)), any tricks for earn more horsepower ?, where i live have alot of hills so .
