Two things come to mind if your chain goes slack then tight.
1. The rear sprocket isn't centered on the hub (poorly made adapter/sprocket) or has a wobble that lets chain ride higher on the teeth in places.
2. There are tight spots (binding links) that aren't allowing the chain to ride the sprocket correctly or a defective chain that has a twist to it. I've seen many kit chains that fall into this category.
A good quality industrial grade #41 chain is all I've ever used with no clearance problems anywhere except the front edge of the clutch actuator cover. But that's normal for all Chinese 2 stroke engines.
