centrifugal clutch
jmr3394
Is it possible to install a centrifugal clutch onto a 2 stroke grubee? If so, is it worth it? And where can i get one and how can i install it?
1. yes its possible
2. only worth it if you stop often and dont want to pull in your clutch everytime
3. Zoombicycles Addon - Centrifugal Clutch (5-3) | 4. Accessories (42) | Parts and Accessories | EHBC Distributors Ltd
adding on a pullstart or centrifugal clutch will be in the way when you pedal, requires wide peddals crank kit or short pedal cranks and maybe even raising engine higher. My engine came with both and was not worth the extra work required,i wish had bought a regualar kit. the pullstart was nice for starting the engine but even tho i had a centrifugal clutch too,i still pulled in the manual clutch,for a lower idle at stop lights.
I never installed either(mine came with both already)so i dont know how hard it is too install.
Install instructions: http://www.zoombicycles.com/downloads/addons.pdf
