When you say the cover gasket do you mean take the magneto cover off then put a bead right on the gasket or put a bead on the outside of the cover? Never thought of that that would work well I was pretty frustrated the other day when the new carb refused to run well enough then plain refused to start today with the stock carb it ran great then after stopping at a store I Could not start it on the way home, brought upstairs and did a spark test pulled the plug out then put up to the head turned the wheel no spark took the kill switch out, no spark checked all connections then remembered the magneto.A bead of silicone sealer on the magneto cover gasket and a glob where the wires exit the case should seal out any moisture.
Also I later discovered that the ring gasket that goes in where you mount it to the head was not installed it fell out and was in the box could that have casued the problem I was having?Some thoughts off the top of my head....
- Check the needle position.. it may need adjusting up or down.
- Make sure the nut that holds the choke lever assembly together on the carb is good and snug.. if it's loose you'll have trouble keeping the intake open properly.
- Check the stem that draws fuel out of the float bowl (that the needle drops through), sometimes they loosen a bit and will eventually drop into the float bowl. Even 1/4 turn out of position is enough to really mess up the amount of fuel drawn into the intake.
- Make sure the carb is tight on the intake manifold. Air leaks between the carb and jug will make it hard to tune in. One trick I've used for this check is to remove the air filter and open the choke then point a small very bright flashlight into the intake. Looking at where the carb meets the intake manifold, if you see any pinpoints of light around where the carb is fitted to the manifold you have an air leak.
I just got my motor kit installed and I am wondering about a few things first the carburetor in what direction do you turn the idle screw to shut the fuel off so if i need to increase or decrease the idle which direction does what?
The clutch cable has 2 springs one to protect from heat but what is the purpose of the other? I think it goes in between the cable housing and the idle arm. Is it really needed?
The problem I am having is when the spring is installed, I can't get the clutch arm far enough so that when I pull the clutch it disengages. The other issue is the chain how tight is too tight? And does anyone know how to put the chain guard on?
Welcome to motor biking!
Goal is to ride everyday with no vibration and no leaks.
this is a hard task.
Your clutch arm can be articulated with your hand and adjusted w/the lil star nut, under the right side cover. The cable can be adjusted for optimum position w/the set screw @ the end of the cable.
As for the carb well they are not the best I've tried and installed at least 20 Dif. 1's.
the only adjustment on the stock carb is the idle,& good luck get'n 1 to idle .
here's the 1 I found to be best. 1/4 inch play in the chain is optimum, and if your bike is new, this will change every 10-12 hours-until its through strecth'n, don't put the guard on until your thrugh mess'n w/it which is never
if you spin the back wheel w/the spark plug out and grab the wire (blue or white) you will feel the lil shock---this will tell you if it is working or not.
Yeah, that would have an effect. I'd put that back in there. None of mine have come with an O ring out-of-the-box (yet).
You measure chain free play by pushing up on the lower chain run as close to the middle distance between the 2 sprockets as possible. Sprockets are never perfectly round so you need to find the tight spot. With the clutch pulled in, roll the bike to rotate the chain and sprockets. Check the tension frequently to find the tight spot. You may need to roll the bike around alot to find it. When you have found it adjust the rear wheel to give the chain 1/2 inch minimum to 3/4 inch maximum freeplay.
The white wire cannot be used for generating the signal to the CDI for spark.
The favored spark plugs are NGK. Use a B6HS to start with.
Use a B5HS for cold weather, B7HS for hot weather or a B8HS for scorching hot weather.
Spark plugs are rated in temperature ranges. The higher the number value, the colder the plug. You want a hot plug in cold weather and a cold plug in hot weather. It really does make a big difference.
The factory spark plug wire is good, but the factory cap that snaps onto the spark plug is garbage. Most folks go the easy rout and replace the spark plug wire with a high performance wire such as the one that SBP sells or use an automotive one.
It is tricky to remove the wire from the CDI as the factory glues them in place. Also, to help hold the wire in place and conduct electricity properly there is a metal screw in the spark plug hole of the CDI box that threads up inside the spark plug wire to make proper contact with the electrical conductor in the wire. Usually this screw is plenty good enough to both transfer the electricity and hold the wire properly, but for some ungodly known reason the factory likes to use glue too. Because of this overkill method, when you go to remove the wire it typically breaks off flush with the CDI box and you need to carefully pick the remaining wire out of the CDI box with whatever you have
that is sharp and strong. A mechanic's pick set and tweezers come in handy. Sharpened nails or coat hanger wire can work as "shade tree" mechanic's picks too.
The replacement wire simply threads into the hole, over the screw.
