I have switched out two cdi's and a magneto. The last time the two were switched out the engine started and ran rough for a half mile and dead again. I found a little oil in the magneto area with metal shavings the first time I switched the magneto but after the half hour ride it looked fine but will not turn over.
This engine only has about two months on it and I have done everything except a full rebuild. What I am wondering in if something internal can cause magnetos to fail.
On the second magneto switch I extended the wiring to the cdi because of apehanger handle bars. I used a little thicker copper wire (can that lead to magneto failure?)
everything was soldered up with shrink tubing and looked good. Any ideas would be appreciated.
