carb to big for intake
TNault
32
Florida
my carb plastic o ring was degrading so i took it out to look at it and it broke in half.. now i need to find something to replace it with.. anyone have any ideas? oh yea just to be clear its not the black rubber o ring that is suppost to create a seal its the white one that goes over the intake port to keep the carb from falling off
Goat Herder
Gutter Rider
Apr 28, 2008
6,248
10
N.M.
Look around you may find some like wise [thickness] plastic curl it up and stick it in there. I would do that right off perhaps but only if it was like wise. If not you will prolly crack the carb body tightening it up. One of our vendors I am sure sell one by now I would look around.
2door
Moderator
Staff member
16,326
123
Littleton, Colorado
When I need something like that and can't find it in my junk drawers I head off to a good hardware store and start browsing the isles. Especially the plumbing section for something like a bushing you're talking about. As for compatibility with ethanol, there shouldn't be that much contact if it is only a spacer, or bushing that sets in the carburetor throat. Even Home Depot might be able to provide what you need, but a hardware store would be a better choice.
Take the carb and intake manifold with you and start searching.
earl.k
242
PA! USA
would that part come in a card rebuild kit.. because iv seen a few of rebuild kit for garbs online. i cant remember where tho..
adam valentine
221
Mission Kansas
creative engineering makes a ported intake for the cns carb that you don't need the white plastic at all that is how i would roll if i was you they are 20 bucks on spooky tooth and will give you more power
Hammond Egger
270
Tucson, AZ
The one I need is 19mm ID and 24mm OD. Dellorto doesn't have one that size. But thanks for the link, gives me some new search ideas.
superbob
17
Florida
I like the idea of a new, tighter intake instead of the rtv silicone. I have to rotate my carb to get at it and make needle adjustments, etc. Looked on spooky tooth. They show a steel intake manifold for 6.00 but give no further info. No quick way to tell if it is for a CNS carb so I e-mailed them.
I think I'm taking the twenty bucks and going with the NT, if only to keep from further messing up my break-in period with bad carburetion, air leaks and this mysterious overrevving. I don't mind a touchy CNS carb if it turns out to be more versatile and adjustable in the end, but if I already have to pay 20 bucks to begin to fix it... and my patience is wearing thin too.
