Carb float failure!!!
mike373
14
Only an hour or so on this engine now.... Drove it today after work... got about 3 blocks away, when the engine quit. I looked down, and fuel was pouring out of the air intake. I shut off the tank fuel valve and pedaled home. I suspected the carb float was stuck. Took off the carb bowl to find that the float was full of fuel!!!! Anyone else heard of a leaking float? Looks like I will just buy a new float. Hope this isn't a common thing.
Mike
nitroscope8
80
Long Island, New York
Only issue with our carbs is that the metal ring the float pusheso n gets a little tweaked and lets some extra fuel in and it leaks a little. A simple removal and slight bending brings it right back.
mike373
14
The funny thing is that I cant seem to get the fuel out of the float. Cant find a visable crack anywhere... but a tiny amount of fuel seems to slowly seep out from the inside hole. I was thinking of drilling a tiny hole in it to suck out the fuel.... but what could I use to seal the float with?? I dont know any glue or material that would stand up to being submerged in gasoline.
I was thinking that my float failed from vibration, causing a hairline crack in it for fuel to seep in.
Mike
Pablo
Dec 28, 2007
3,689
29
48
Duvall, WA PNW
www.sickbikeparts.com
There are fuel proof epoxies. And indeed some folks have drained the float with an extra tiny hole. The trick may be getting all the oily fuel off the float for the epoxy to bond.
A new carb is $22, so don't kill yourself.
mike373
14
I was thinking of making a float out of cork material.. What does anyone think? At least it wont fill up with fuel.
Mike
Ghost0
763
Bellingham, WA
Cork? Not a good idea, it will get tore up from moving around and deposit bits of junk in your carb clogging your jet. If you can clean out your old one and find the hole you can use a soldering iron or equivalent to melt the hole closed.
Dave31
11,199
47
Aztlán, Arizona
Yes, cork will not work.....They do have plastic welding kit's at Harbor frieght...but I think a new carb is even cheaper then that.
