But do I even have to elaborate on the huge difference between a car's charging system and trying the same thing with a bicycle? A car's engine is the "generator" and is running 100% of the time and is turning the alternator at the speed it needs to operate efficiently 100% of the time and keeps the car's battery topped off. Most of the electricity that the alternator is producing is to power the car's electrical system, lights, accessories etc. This power is NOT being produced to propel the car down the road. That's the duty of the gas engine. On a bicycle, 100% or close to it, of the energy the bike's generator/alternator produces is needed to actually propel the bike itself. An ebike runs out of juice pretty quickly. You can't generate enough power from a generator fast enough to keep the bike in perpetual motion, thus you'll use up what reserve power you have in a short time and have to stop and replenish the batteries. On a bicycle, the weight of the generator, even though it's lightweight by generator standars, would seriously lower the efficiency of the bike's overall performance because even a 29 lb. generator weighs more than the entire bike in many cases. This theory has already been thought through countless times and if there was a way to keep an ebike going perpetually, we'd be seeing it and at a very high price.
If the term "capacitor" is actually in reference to the so-called capacitor battery technology being developed by EEStor in the Austin area and supported by ZennCars, this charging theory might change. They claim to be able to charge an electric car's entire battery bank in 5 minutes with enough juice for 250 miles or more.
Ahh, some real discussion in this thread, finally! Okay, first of all, perpetual motion is a dream, for any vehicle, anywhere. Can an electric bicycle travel endlessly, because it has a generator attached/trailing along behind it? Of course not. But, it will go farther than it will without the generator, because although the generator isn't replacing 100% of what is being used, it is replacing quite a bit of it. Is this the solution for people who ride 40 or 50 mile per day? No, but then again, a 2 cycle in-frame is also a poor choice for someone who rides that far, that often. That guy would be much better off with a 4-stroke engine, although obviously a 2-stroke would suit his needs much better than an electric bike. Did you miss the portion of my post that you quoted, where I said "you would want to have a detachable generator attached to your electric cycle/scooter. So you burn zero gasoline for 98% of your trips where battery power alone is enough, then attach it for those few times per year that you need more range."? Those are the people for which a detachable generator makes perfect sense, not for you.
