The wet oily deposits are a result of your 16:1 oil ratio and one of the reasons we always suggest against that much oil. Nevertheless the porcelain isn't looking too bad as far as your air/fuel mix is concerned.
Break-in procedures are always going to get many opinions about the best way. Some will tell you to baby it with only very short bursts of WOT and others will tell you to run it hard. I guess I fall somewhere in between. If your engine is occasionally breaking into a good 2 stroke at WOT then you're in the ball park as far as carburetor jetting. You could safely reduce the oil content down to a 32:1 mix at this point without damaging anything. Then run the engine through a couple of gallons and you'll be well on your way to having an engine that is considered to be, 'broke-in'.
As was said above, don't be too concerned with performance issues until 200 to 300 miles. These little engines never perform to their full capability until then and you won't be able to tune properly before that time. Be patient and ride it as much as you can. You'll notice the increase in power the more miles it accrues. Good luck.
