Brakes
Discussion in 'Motorized Bicycle Swap And Shop Sales' started by RichP, Aug 23, 2016.
  1. RichP
    RichP New Member
    Jul 30, 2016
    16
    Hello, i'm aiming at a bike/motorised bike build. I'm currently looking for parts, specifically, what is my best option for a fork that will accept dual front brakes please? As in one disc brake on the left prong of the fork and the other on the right. Obviously this needs a dual mount (1 each side) Also i'm in the u.k please, please can somebody point me in the right direction. Thanks
  2. MotoMagz
    MotoMagz Well-Known Member
    Aug 2, 2010
    1,610
    561
  3. RichP
    RichP New Member
    Jul 30, 2016
    16
    Been meaning to thank you for his info for a while now. Cheers
  4. TheNecromancer13
    Jan 21, 2015
    610
    20
    IMO you don't really need dual front disc brakes. I run a single front disc brake, 200mm rotor, and it gives me enough stopping power that I have had to use the rear caliper brake exactly once, when a puppy ran into the road in front of me. And this is on a bike that can hit 40 mph. Unless you are doing it for looks or aren't running any type of rear brake at all, I would generally say it isn't really necessary. But if you do want to do it, I have seen some adapters that you can put on single disc front forks that will allow mounting of a second one.
  5. RichP
    RichP New Member
    Jul 30, 2016
    16
    Surely you must almost go over your handlebars though?
  6. TheNecromancer13
    Jan 21, 2015
    610
    20
    Na, I have front suspension which prevents that.
  7. RichP
    RichP New Member
    Jul 30, 2016
    16
    Hi, can anybody tell me where I can get a disc brake hub adaptor that will fit a sprocket with more than 30 teeth please?
  8. TheNecromancer13
    Jan 21, 2015
    610
    20
    custommotoredbicycles.com has them for several mounting bolt patterns. They are of good quality.
  9. RichP
    RichP New Member
    Jul 30, 2016
    16
    Thank you but I am not finding any disc brake adaptors. Do you have a link?
  10. TheNecromancer13
    Jan 21, 2015
    610
    20
  11. RichP
    RichP New Member
    Jul 30, 2016
    16
  12. TheNecromancer13
    Jan 21, 2015
    610
    20
  13. bluck
    bluck Active Member
    May 2, 2016
    125
    29
