boomarkert
So my engine (66cc Skyhawk GT5) has been running HORRIBLY, and I decided to open up the motor... The clutch cover had a ground down ring inside where the three pins sticking out of the bigger gear are... The whole assembly inside the case was pushed over about 2mm!!!!! The screw on the smaller gear was all loosened and bent.
I was able to push the whole assembly back to the correct side by using a hammer and a piece of wood, then I tightened the screw that was loose...
After riding it again for a little bit, I'm pretty sure it slipped right back out of place.
HOW DID THIS HAPPEN?! And how do I fix it?
This new build is really starting to make me lose interest in these things
. Getting too angry lol
