Is there a label on the wire pair at the connector.
POST #35
The wiring on the controller leads are set out as so, from top of picture...
1. Brake Signal - Red/Black.
2. Brake - Yellow/Black.
3. Derailleur - Red/Black/Blue.
4. Charge - Red/Black - (with two cut wires also Red/Black)
5. Pilot Lamp - Red/Yellow.
6. 2 thin bare wires - Red/Blue - ?
7. 2 Thick bare wires - Black/Red (I think these are battery wires?)
8. 2 Thick bare wires - Blue/White (I think these are the wires that goto the motor?)
The list of the wiring in post #35 and picture. All wires have connectors fitted and a sticker on connectors donating what it is, hence my being able to post a list. The only wires that didn't have connectors on were - 6. 7. 8, these wires were BARE when the controller arrived, barring the thick Red n' Black, which had a piece of white tape around them.
Wires
In the picture you'll see they have selotape/clear tape on them. When they fell off I realised they had been connected but the wires had been cut and were held on with tape.
..And do you have the throttle connected right.
I have had more bad throttle assembly than controller "out of the box" problems.
I took the scooter throttle off my trailer (I didn't use new throttle), so I know this throttle works.
There are 3 wires on the Scooter throttle...
Red.
Black.
Green.
There are 3 wires on the Controller (with a connector and sticker marked Derailleur. This fell off/held on with selotape/ clear tape).
Red.
Black.
Blue.
I connected...
Red to Red
Black to Black
and was left with a Throttle Green wire and a Controller Blue wire which I connected together. Im assuming that's how they go unless there is another combination of the 6 wire connection?
I think I'll have to take the controller round to my mate Peter, he has a continuitie? tester. The only thing left after that is hook up - 6. 2 thin bare wires - Red/Blue - ? together and see if anything changes.
Regards
