Hi all,
In the aircooled world of VW's, there are many ways to increase HP. Larger valves, high lift cam, bigger carbs. But after you do all that, the best way to increase HP is to put bigger jugs in and put in a stroker crank.
I pulled apart my first 2 stroke motor that had about 2000 miles on it. The cylinder doesn't look like too much could be bored, but could a stroker crank, maybe with a shorter rod be made? Has anyone looked into larger pistons? I'll bet many on the group would buy an upgrade kit if it had a larger piston and matching cylinder. 80cc, 90cc?
Jim
Jim
