yeah i would only use a steel frame. however my real concern is the inner dimensions of the frame ive seen people fit them into cranbrook frames and worksman bikes. ive been looking into this frames. theyre similar to what phantom was using before they went electric http://www.cdhpower.com/gt-c-gas-frame-w-fuel-tank-3-4l-black.html
Bad idea to run that frame. To fit the 212 they also use a short machined valve cover. By doing so they do away with the stock breather and just run lines to a catch can. As a result their oil gets contaminated with blow by gases quickly. I found this out when one of his customers told me he has to change his oil every 30 miles. That’s not very good performance IMO. When I used to commute on a 212 I would change my oil the same time I did the rear tire, or about 6-800mi.Hi Ruby478. Ghetto Bike uses that aluminum frame or a frame very similar to the one you mentioned with the 212cc predator engine in his Bikes For Sale. He has the respect of members of this forum who have many years of experience with motorized bicycles. However, he reinforces the entire length of the seat tube with a solid steel seat post, uses a modified moped suspension fork, mounts the engine securely with high quality machined parts and I'm confident that the chains are aligned perfectly.
I have the 212cc on a 26" Sixthreezero frame which has tons of room for the engine. The problem, the CNC mount is not long enough toChicago Schwann cruiser is best. See my threads.
is that 26 have an extended frame ?I have the 212cc on a 26" Sixthreezero frame which has tons of room for the engine. The problem, the CNC mount is not long enough to
couple to the frame. I did get the engine mounted and it's fairly level and sits low but forget about putting a pedal sprocket on the bike.
I ordered the bike off of Ebay and the order was for a single-speed with coaster brake got a darn 7-speed instead with a small 1" wheel
hub. That's the biggest problem, I need the mag wheels.
