Bike won't start
BenchDweller
23
9
44
Having a new issue with a bikeberry 66/80 I been running since January.
Motor has ran good until today. When I was out and about during start up the revs stayed a little high at idle until the bike warmed up. After a quick warm up and and shut down I tried to start the motor again. This time.no matter what the bike will only give a put, put, blech, put, put blech at wide open as long as I keep peddling. It won't stay running. Almost like there is bad spark but I checked for spark and am.getting it. The thing is flooding right out and I cleaned and dried the plug twice. Any idead? Please don't tell me the cylinder is blown already. I looked with a bore snake cam and the walls seem good.
BenchDweller
23
9
44
That's what thought immediately but the motor is getting gas. I just thought I'd ask to.see who comes up with things to think about.
If its fuel the only thing I can think of is the crankcase is going to have a pool in it when I tare into it this afternoon. The motor is just getting past the break in and this happens.
Tyler6357
1,293
292
83
Santa Barbara, CA
Check your pipe, make sure it's not gunked up with oil and that air will flow through it. 16:1 is too much, I use 24:1 for break in and 32:1 after
BenchDweller
23
9
44
got her all apart
Pipe isn't bad at all. Piston full of carbon and the piston backwards. Rings look good though.
Crank was soaking wet with gas nix though . When I took mine apart the first time I must have had one too many and glossed the piston over.
Rebuilt the carb after a chem dip. I am leaning towards the float got stuck open and was pouring gas into the crankcase and flooded her beyond all get out.
"If a spare part is cheap, it is because it sells often and you should always have two on hand"
FOG
282
617
93
71
On the backwards piston there are reports of them being marked wrong. The important thing is the ring gaps have to be on the intake wall of the cylinder.
If the gaps run up and down in the exhaust port they can snag and break things.
  • Like
Reactions: Tyler6357
BenchDweller
23
9
44
I know, just mentioning it. Luckily they didn't snag before I realized it
  • Like
Reactions: FOG
Venice Motor Bikes
Mar 20, 2008
7,093
1,319
Los Angeles, CA.
If you have spark & the plug keeps getting fouled... here are the things I would check for...
Is the choke lever all the way down?
Are you running 32:1 (or 40:1) gas/oil mix?
Is the float in the carb stuck?
Did the main jet come loose inside the carb?
This last one is kind of rare, but I've seen where the CDI went bad & the plug still had a spark (like the timing of the CDI went off)?
BenchDweller
23
9
44
after a tare down and repair I get it to.start but low.power and only stays firing at certain throttle.positions. I am almost convinced its an ignition timing issue.
BenchDweller
23
9
44
It starts and runs now. Starts quick.it just doesn't seem to warm up and when it finally does it just farts right out. Going to get new spark plug see if that does anything.
