Bike won’t idle and loss of compression
MotorcyclesMan!
9
64
Hi everybody it’s been a while since I last posted but this problems driving me crazy. So my first build which has been solid for 2 years just gave up on me about 2 months ago. The bike just wouldn’t start so I do the usual trouble shooting and change the plug as there was no spark. Now the winging starts but a whole boat load of problems begin the bike has no where near the power as before and only runs in wide open throttle after pedaling to get it some speed. The bike will not idle and misfires occasionally. I have replaced every single seal on the engine changed the cdi the magneto the plug oiled and regressed everything cleaned the carb tried a different carb. I checked for air leaks on the engine possible warped head and head gasket and couldn’t find anything. I have disassembled the muffler and cleaned it and used a different one all together and I also got rid of the kill switch and nothing will get the bike back to where it once was. I could try a top end rebuild but I don’t want to unless I have to. Any help at this point would be greatly appreciated.
Greg58
4,547
1,364
Newnan,Georgia U.S.A.
Larry has you on the right track, I would check the compression. That will tell you if the rings are sealing. I have the type gauge that has the hose that screws into the head, I can then tape it to the tank so I can see it as I pedal. Be sure to open the throttle to allow air to be drawn to get an accurate test. From 80 psi up will run ok.
MotorcyclesMan!
9
64
Hey sorry for the late response I just got a compression gauge how exactly do I use it. Take spark plug out plug this in do I leave choke closed or open. And if I’m doing this stationary without riding how would I go about it. Thanks
