It doesn't bogg at full throttle. Bogs a little starting up and takes a little pedaling to get it to start accelerating. The problem is it just seems to stop accelerating after 1/2 throttle. Like 1/2 throttle sounds just like it does at full throttle. I have a 68 jet in now. The biggest that came with jet kit I have is 70. So I'll put stock back in there. Because it had good bottom end and top end with stock everything. Only difference now is I've ported it.If it bogs at full throttle you probably need a smaller jet. Raising or lowering the needle clip controls the mixture from idle to 3/4 throttle. So try a jet with a smaller orifice not number till you start getting more top end. Be careful to check the plug color to keep from getting it too lean, the porcelain should be light to medium brown. After you get the jet right move the needle up or down till it runs right, a 71 is what most stock jets are.
