East82
After reading thru some threads and being directed to a search by decoherence I wanna run this past you all and see if it makes sense and if there might be a better way.
The mounts, top and bottom, along with the intake manifold are studs. The outtake manifold is bolted on. My idea is to tap the mounts and cylinder @ 1/4 - 20 and use quality bolts, longer ones for the mounts and around 1" length for the manifolds. This will do away with all the studs.
Is this a good way to go about it or is there a better way? I'm looking to secure the engine to the frame the best way and to prevent stripping all the way around.
Thanks
Thanks
