Anyone seen this kind of fail before?
seen a lot crack like that - usually when factory misses the key
these are both intact and uncracked, and not stretched out of round
This engine was a couple hundred mi into a fresh rebuild before I discovered this. Oh well! After seeing your post I now assume things were not quite right with it to begin with. Also, a good practice is to tighten that screw which holds the gear in place using a hammer and punch. Most my issues have been that screw loosening which results in a loud screeching sound from the screw in contact with the backside of the cover. All kinds of food for thought here. Thanks crassius!
http://motorbicycling.com/album.php?albumid=1645&pictureid=9717
I just had the exact same failure. The engine is two weeks old, but I rarely have time to ride. The small gear looks like it's made from sintered metal.
we've pretty much concluded that it is due to a factory worker failing to grease that gear
when you replace it, be sure to grease it properly
