Anybody try a Comet torque converter on a bike?
Discussion in 'Motorized Bicycle General Discussion' started by fitzmotor1, Sep 15, 2012.
  1. fitzmotor1
    fitzmotor1 New Member
    Aug 26, 2012
    Comet converters are the standard for mini bikes and go karts, anybody ever fit one to a bike? aside from being big, heavy and rated for higher horsepower than most bikes, the idea is great.
    Just a crazy thought that I was hoping somebody has tried.
    Thanks.
  2. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Howdy Fitz. A bunch of folks have used CVTs. I have had one on a Harbor Freight engine for months but have yet to get it on a bike. Shafts on most engines that will work for our thing are 5/8 and needs to be shimmed up. Also a CVT needs to be further reduced, ratio wise for a conventional sprocket drive. I have yet to really work on either of those puzzles but many have with success.
    http://www.google.com/cse?cx=partne...=1315j713437j4#gsc.tab=0&gsc.q=CVT&gsc.page=1
  3. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    what CVT do you think is the best one currently?
    #3 JonnyR, Sep 15, 2012
  4. fitzmotor1
    Aug 26, 2012
    The Comet asymmetric 30 is about as close as I can find, rated 3-8 hp, I am wanting to try it, but I dont know if it will be ok, it's heavy, a 3/4 belt to drive which may be a power loss as it goes through the front and rear pulley ratio changes and the ratio goes from .90 high to 2.68 low, and it is about $135 thats why I was hoping somebody had tried one or something similar.
  5. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    "...thats why I was hoping somebody had tried one or something similar."
    It has been. There are many on the link I provided above or use the search feature above and in the center.
  6. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    They're wide, go through belts rather quick and they don't pedal very well. If you need to pedal with engine off, you need Lance legs.
    Some might argue if they wanted to pedal, they wouldn't have put an engine on a bike - but well, you never know when you might need to pedal.
  7. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    I have one on one of my bikes and there seems to be a lot of power loss using it. Iam using it with a HF 200cc.
  8. stewpedassle
    stewpedassle New Member
    Feb 16, 2012
    89
    i had 80t4g belt had 5 bearing shred found cvt for pocket bike 49cc X1 X2 Ninja Pocket Bike Cvt Transmission Gearbox Tm03 does anyone know anythingabout it if will work ect. thank guys name says it all lolzpt:-||laff
  9. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    This Comet torque converter seems to rob to much power (I cant get past 35 mph and it slows way down on the hills?) is there a trans that we could use instead? Do you guys think a rear derailer would hold up to the power of a 200cc HF engine?
  10. atombikes
    atombikes New Member
    Feb 14, 2010
    525
    Unequivocally "NO".
  11. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    How about a trans? Maybe something for a pocket bike?
  12. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    alot of pocket bike transmissions are built into the engines(i like this next build for me)
  13. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    Theres got to be a better drive system for a 200cc HF then a straght one speed chain drive or a CVT?
  14. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    the jackshaft with a gear reduction is seaming to be the best right now from what i have been reading
