analog speedo?
Discussion in 'Motorized Bicycle General Discussion' started by oldtimer54, Oct 13, 2011.
  1. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    Anyone know where to buy a analog speedo that will work with a high speed (50 mph+) motorizedbike?
  2. thegnu
    thegnu New Member
    Sep 15, 2011
    982
    wow check out summit racing . all speedo's use the same cable you may have to get a bicycle cable an drive an with minor mods it will work.
  3. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    Iam trying to build a bike that I can reg but I need a spedo and from everything I read the pyramid brand unit is junk. Ive installed a running/brake light a nice 10 watt LED headlight, a 100 watt generater with a charger/regulater, a 3AH 12 volt battery put it into a waterproof box on my rear rack but I need a spedo to get legit. Sooooo any ideas as what I can do? (yes this is just a long winded BUMP lol)
    #3 oldtimer54, Oct 14, 2011
  4. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    There stuff costs waaaay to much but thanks. (I wouldnt know where to start with the mods I would need?)
  5. thegnu
    thegnu New Member
    Sep 15, 2011
    982
    Ok option no.2 if you were to scavenge one from a auto salvage yard, I have had these units out before from an 88 jeep wrangler after its out of the dash its housing is approx 4 inch in diameter an about the same in depth , this may work for you . I hope this is a good lead for you , an I would be happy to walk you through the mods to make it fit .
  6. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    Ok start walking wink.
  7. azbill
    azbill Active Member
    May 18, 2008
    3,367
    I have heard whizzer speedos hold up to our speeds ;)
  8. thegnu
    thegnu New Member
    Sep 15, 2011
    982
    lmao, your gonna have to wait till I can ride mine to ya I'm to lazy to walk!
  9. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    Sounds good but I would have no idea how to mod my HF 6.5 HP powered bike to run one unless someone starts walking. (me through the how to lol)
  10. F_Rod81
    F_Rod81 Dealer
    Jan 1, 2011
    1,033
    Your going to want to find a "Whizzer" speedometer. The dimensions are virtually the same, and the whizzer speedometer is much more accurate then one from a supplier or from off ebay. It might be higher priced then other analog speedometers, but it's accuracy is within 0.5 mhp.
  11. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
    Sounds good but how would I hook it up to my bike?
  12. tim turbo
    tim turbo Member
    Nov 18, 2009
    186
    pino.Forget a bout it! You do not need to go 50 MPH, buy a cheap speedo and call it good. YOU ARE RIDEING A BICYCLE THEY DO NOT GO 50 MPH !!!!!!!!!!!!!!!!!!!Nuff said
    #12 tim turbo, Oct 15, 2011
  13. oldtimer54
    oldtimer54 Member
    May 15, 2010
    539
  14. mesmith
    mesmith New Member
    Jun 30, 2011
    47
  15. mesmith
    mesmith New Member
    Jun 30, 2011
    47
    Pirate Cycle has them for $15.00
  16. bandito
    bandito New Member
    May 22, 2009
    783
    Olds getting this registered as a M/C if i'm correct. 6.5 hp............
  17. anim8r
    anim8r New Member
    Jul 15, 2011
    243
    the pic's fuzzy, but isn't that the one everybody sells that says SPORTS at the bottom & has a racing flag on it?
    I got an analog speedo (different brand/model) & it just won't work on a motorbike from what I can tell. The odometer works because it's a direct gear-driven connection. But the speedometer part has this really sensitive wheel balancing on the needle's hub, & it's hooked up to a spring. From what I can tell, the cg puts out such strong vibrations that this delicate little mechanism is hopelessly overpowered. The vibration frequencies can do some weird things, like make the needle run inverse to your speed... it shows you slowing down as you speed up.
    I could be wrong,, but that's what it looks like. Maybe I've just got a crappy speedo, or mine's broken, or I'm riding though some Bermuda Triangle-type zone. But I have read complaints from other cg riders saying that the most common retro speedos are just no good.
  18. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    I have used several of the $15 speedos. They are very inaccurat in speed. Typicaly at 35 mph they say 50.
    In my avitar photo above, I'm actualy doing 38 mph.
    I recently bought an old Puch mo-ped speedo off e-bay for about $20. It was marked in MPH, and I tried it on the cheapo's drive cable, and I was suprised to find that it is very accurate.
    #18 wayne z, Dec 25, 2011
  19. donphantasmo
    donphantasmo Member
    Oct 3, 2010
    360
    Don't know if you've tried this, but
    Old Skool Mechanical Speedo
    Lemme know if that would work. I'm actually looking at this for myself..
  20. CTripps
    CTripps Active Member
    Aug 22, 2011
    1,311
    Yeah, if those work I could use a couple myself, if the RPM/strain of the MAB doesn't hurt them. From the pic it reads to 60KPH, I don't exceed that (often), so it might work out.
