Acceleration without power
Discussion in 'Motorized Bicycle General Discussion' started by unknown03, Aug 16, 2013.
  1. unknown03
    unknown03 New Member
    Aug 8, 2013
    22
    Whenever i do wide open throttle uphill, my bicycle would make the accelerating sounds but it only gives little power. Which means, i have to pedal to help it.
    My bicycle seems to run very well on flat roads except uphill.
  2. xseler
    xseler Well-Known Member
    Apr 14, 2013
    2,842
    78
    Sounds to me, that your clutch needs to be adjusted or the clutch pads need to be replaced. On level ground, there isn't as much 'resistance' to movement as there is going up an incline.
    Good luck in your fix!!
  3. unknown03
    Aug 8, 2013
    22
    Could you please tell me how to adjust my clutch?
  4. xseler
    Apr 14, 2013
    2,842
    78
  5. Kioshk
    Kioshk Active Member
    Oct 21, 2012
    1,153
  6. Huffydavidson
    Huffydavidson STREETRACER/MANUFACTURER
    Jan 29, 2012
    1,077
    One the best ways to learn here is try to do a search yourself.
  7. unknown03
    Aug 8, 2013
    22
    Thank you guys for the response.
    @kioshk i did that already few days ago. However it doesnt work to me.
    I might be doing it wrong but thats why im here to ask for help.
    I did a lot of research.
    My problem still remains the same.
  8. xseler
    Apr 14, 2013
    2,842
    78
  9. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,775
    89
    look up 4-stroking here & on youtube - you may need to find a sweet-spot in your throttle position to get it to 2-stroke uphill if the engine is new
    also, it may be that your compression is low - do you have a compression gauge?
  10. Kioshk
    Oct 21, 2012
    1,153
    Your clutch-spring, the BIG one on the drive-shaft between the clutch and drive-sprocket, may need more compression. You can access the adjustment nut by unscrewing the clutch-cable saddle. You'll need a small allen-wrench or screwdriver to perform the procedure...do some searching, Grasshopper.
  11. Kioshk
    Oct 21, 2012
    1,153
    Also, your clutch pads MIGHT be contaminared with water or oil; this is easier to remedy. Remove the clutch-plate and spray it and the clutch-pads with plenty of brake-cleaner. Be sure to plop a small dollop of axle-grease on the TOP vertex of where the gears mesh.
  12. unknown03
    Aug 8, 2013
    22
    I fixed my problem already.
    What i did is locked in the clutch lever and adjust the flower nut clockwise with my finger. I did try adjusting the flower nut before but only using sparkplug tool as shown in this video: http://www.youtube.com/watch?v=zAp8h9WRXwI
    However that did not fix my problem. SO instead, i used my clutch lever to adjust it.
    then ZOOM! :D
  13. unknown03
    Aug 8, 2013
    22
    Just a question.
    There are bearings right behind the clutch-plate. Should i avoid spraying those bearings?
    Or do i need to take those pads out 1 by 1 and spray them?
  14. maniac57
    Oct 8, 2011
    4,486
    7
    Spray everything clean, then put a LITTLE BIT of oil or grease on the bearings. Too much will just sling around and make it slip.
  15. unknown03
    Aug 8, 2013
    22
    Alright, thank you sir for the reply :D
