I’m trying to install lights front, back, break and turn signals. The only thing I can’t seem to get going is the turn signals. I don’t have a clue where to start.
Heres something you might want to try. You can also have one controller operate 2 units. That way you can have front and rear signals. The lights are also visible during the daylight. When watching the video slide left on it for the second video.I’m trying to install lights front, back, break and turn signals. The only thing I can’t seem to get going is the turn signals. I don’t have a clue where to start.
Many of them however can't be seen during the daylight hours.Search 'bicycle turn signal' on eBay... You'll find a ton of options.
Are you using LED lights? Flashers need a lot of power running through the bulbs to switch on & off... (LEDs don't have enough power)I have a flasher relay but can’t get it to work with the turn signals set up I’m doing.
Yes they are LED lights, 12 volt battery. How can I get them to work?Are you using LED lights? Flashers need a lot of power running through the bulbs to switch on & off... (LEDs don't have enough power)
Use regular filament light bulbs instead of the LEDs....Yes they are LED lights, 12 volt battery. How can I get them to work?
I can get them to turn on but they won’t flash, just solid.Use regular filament light bulbs instead of the LEDs....
I know this because I once tried to swap LED bulbs into my old VW bus, & the flasher wouldn't work properly until I put the old bulbs back in!
exactly!I can get them to turn on but they won’t flash, just solid.
My 67 VW Bus uses single bulbs with dual filaments... I was considering a few options of adding extra bulbs & things like that, but I ultimately decided to keep it simple, (& keep it stock).Norm I had the same problem using LED bulbs in my ‘50, I kept the LED’s in the taillights for the brightness and used standard bulbs in the front turn signals.
