80 cc throttle issues
Discussion in 'Motorized Bicycle General Discussion' started by mobbin, Mar 9, 2016.
  1. mobbin
    mobbin New Member
    Mar 1, 2016
    the throttle stays at full speed i cannot control my speed, i slow down only by using my brakes , Any advice on this?
  2. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    check your carb. slide is most likely in backwards, and sitting open.
  3. Flathead
    Flathead Member
    Aug 8, 2015
    49
    Check cable to handle?
  4. donphantasmo
    donphantasmo Member
    Oct 3, 2010
    360
    Many things can be the problem. But, since this is a very vague entry, I can only tell you a very vague answer.
    Check every connection, from throttle (where you twist) itself, connection, to the pin in the carburetor.
  5. 2door
    2door Moderator
    Staff Member
    16,301
    26
    Welcome to the forum, Mobbin. You've come to the right place for help. When asking for advice it's always a good idea to tell us what engine and carburetor you have. Is it a 2 stroke or 4?
    Assuming it is a Chinese 2 stroke engine the problem is very possibly what Legwon suggested. The throttle slide, or barrel, in the carburetor will go in two ways. One way it will give you the problem you're having. The barrel has two slots; one on each side. The shorter slot should align with the idle speed screw. The longer one should align with the small pin you'll see protruding from the bore where the barrel rides.
    With the air cleaner removed, look into the carburetor and watch the barrel as you twist the handlebar grip. You should see it move up and down. It should be spring loaded to the down (idle) position and lift when you twist the throttle grip toward you as you're sitting on the bike.
    Throttle cable tension is also important. If you didn't find the problem let us know. There are other things we can suggest.
    #5 2door, Mar 11, 2016
  6. leo
    leo Member
    Jul 20, 2015
    250
    could it be outside air leaking into the intake???
  7. Bikeguy Joe
    Jan 8, 2008
    11,529
    Did you install the throttle return spring on top of the slide?
  8. 2door
    2door Moderator
    Staff Member
    16,301
    26
    Six days and the OP hasn't responded. Either he found the problem or didn't like the advice we gave. Too bad people can't respond to help when it's offered.
  9. mobbin
    mobbin New Member
    Mar 1, 2016
    i found the problem it was the screw on the carb that needed to be adjusted to fit . thanks for advice
