gas tanks almost never explode, just in hollywood, they will burn spouting a huge flame, for it to explode it would have to rupture dumping all the gas at once so it could mix with air.
The tank cap is vented. If pressure could build up, so could a vacuum when fuel leaves the tank,and the motor would starve for fuel.But wouldn't the heat from the sun cause the gas vapors to expand thus creating pressure in the tank? I'm not overly worried, Ill just put a white towel over it if I ever do leave it in the sun.
you poor fellow lol you just told a bunch of skeptics you just saw a ufo prepare for their wrath lmboI pulled my phone out then put it out with an extinguisher, the fire went out fine it's just that the burning oil took awhile to go out.
Fire extinguishers put out fire immediately fast. They are designed to put out fire permanently.I pulled my phone out then put it out with an extinguisher, the fire went out fine it's just that the burning oil took awhile to go out.
hi,
i'll buy your block off of you. let me know how much you want for it shipped to colorado springs, co 80921. i mainly need the engine case.
I noticed your clutch cover is off in one of the pics ... do you ride it like that with the gears exposed ?So, after riding my bike for a good hour or so (just about new with less than 200 miles on it), I turned it off and left it outside to cool off. I walk into my house and peek through the window just to make sure it hasn't fallen over and what do I see? A BIG ball of fire and a cloud of black smoke coming from it. The moment I realized that it was my beloved bike that was on fire (-_-), I kindof just stood there in disbelief. My reaction was to run outside and blow at it (lmao), but it was leaking fuel and that was keeping the thing burning. After putting it out with a fire extinguisher, an autopsy reveled that not only did the fuel line harden and crack, but the shut-off petcock did nothing to stop the fuel flow.
The engine was burnt toast (literally) with every possible plastic and rubber piece bunt to a crisp. The engine had absolutely no compression and the plastic air filter cover melted into the carb so it is not salvageable. I'm guessing that the heat warped the thin aluminum engine so it's junk. I have just ordered a new slant head engine from gasbike.net: Silver Slant 80cc 2 Stroke Bicycle Motor - Silver Slant 80cc 2 Stroke Bicycle Engine Kit - 66cc Bicycle Engine Kit and am waiting for it to arrive. Has this happened to anyone else?? Also, do you think that the engine I've ordered is good? It says the fuel line does NOT get hard over time like the old ones lol
Yes, I did pull out my phone and snap a few quick pics
Did that happen to you, or are you just speculating?...and get full of crud, which will make it slip.
So what do we call him now> Bikeguy Joe-ocratese?Speculating is the wrong word, as he doesn't claim it IS slipping. "Will make it slip" is future tense, and that's more like prophesying.
