The_Aleman
<removed out of protest to certain "staff" practices in this forum.>
Just ordered my bearings today, im tired of replacing bushings
I did my conversion this morning, worked out perfect. I am extremely pleased with the results, alot quieter at idle, almost no clutch ring, and the clutch bell doesn't wobble like it always did with the bushing.
If your 4G is for the Huasheng with the clutch in the side of the motoror do you think the EZ Matic trans would be a good way to just get around all the trouble
I think the EZ Matic trans had a bearing for the pulley aswell as a bigger radius pulley too.
V-belt vs. notched.
I've got my one way bearing welded. What did you do when you welded your pulley to your clutch bell could you show a picture I don't understand why that would need welding since it's "press fitted". I'm gonna do the bearing conversion because I'm tired of how loud it is.
cheers
I finally got my 4G bearing conversion done yesterday, although I had to get the man himself out here to do it for me lol
I lack the right tools to do the job, and after watching cobrafreak do the mod, I doubt I could have done nearly as good a job as he did. My Huasheng has quite a few miles and a very beat-up PTO shaft with a banged-up keyway, causing a sloppy clutch. Cobrafreak resurfaced the whole PTO shaft using plumbing putty, made it practically like new, and then finished the bearing conversion.
The result is my engine is now much quieter than it used to be - no more of that 4G ring at idle. My drivetrain is actually quieter now with straightpipe than it was with muffler installed. I still have some work to do before my bike's done being overhauled (it's been down for a little over a month) but I'm looking forward to cruising with motorvation again!
Thanks for your hard work John, and thanks for coming up with this excellent mod!
Cobrafreak,
Thanks for doing the R & D on this great update. I bought the 10 pack of bearings from A Main Hobbies you recommended. Super fast shipping!
I used an electric grinder and had that thing turned down in no time at all.
What did you do at the end of the shaft where there's a void space inside the last couple of bearings? The steel bushing that went inside of oil lite bushing used to take up that space.
Also, is the large washer outside the pulley spaced out so the pulley doesn't walk off the shaft?
Thanks again!
