4 wheel surrey
Discussion in 'Motorized Bicycle General Discussion' started by David D., Dec 3, 2010.
  1. David D.
    David D. New Member
    Sep 12, 2010
    146
    oh and the garden tractor idea is cool... but how would i retain the pedal feature?
  2. msrfan
    msrfan Well-Known Member
    Sep 17, 2010
    1,779
    36
    Sorry, I misunderstood your goal. Retaining pedals is going to be tricky. If the rear axle is turning both rear wheels at once, going straight would be no problem, but with a freewheel on both rear wheels, turns would would be hard because the inside wheel would be trying to keep up with the outside wheel which would be traveling faster.
  3. msrfan
    Sep 17, 2010
    1,779
    36
    SBP offers ratchetting mecnanisms for pedal cranks. With those installed, all the chains would rotate under engine power, but the pedal cranks would freewheel keeping a place for your feet and allowing peddalling when the motor disengaged. The supporting businesses of this forum have a large array of goodies for just about every situation. This is going to be a fun project.
  4. David D.
    David D. New Member
    Sep 12, 2010
    146
    seems to me the outside wheel would just be freewheeling and the inside wheel would be driving.... only one end of my jackshaft would be working in a turn.... Right?
  5. David D.
    David D. New Member
    Sep 12, 2010
    146
    not really a jackshaft i guess, my idea is a full width keyed drive shaft with a sprocket on each end to drive the wheels, and a sprocket to the engine in the center, and a pillow block at each end and one near the center sprocket...
    #25 David D., Dec 4, 2010
  6. David D.
    David D. New Member
    Sep 12, 2010
    146
    oh, and finally a freewheel at each crankset to prevent them turning while under engine power...
    oops just saw your last post...sbc ...ok will check it out.....
    #26 David D., Dec 4, 2010
  7. msrfan
    Sep 17, 2010
    1,779
    36
    The outside wheel may swing around on its own, but it just seems counterproductive or inefficient to drive the inside wheel in a turn. Puts a lot of stress on the power and drive train and may end up with chain skipping and or belt slippage. Driving the outside wheel will make the surrey turn on a dime with little effort.
  8. msrfan
    Sep 17, 2010
    1,779
    36
    The shaft sounds like a good idea, but you can have a shaft just as you describe only with a differential in the center. Also the diffy I'm referring to needs pillow blocks out towards the ends and none in the middle at the sprocket because of the way they're made internally. I've posted a link so you can see what im talking about. I found one on ebay a few years ago for $30. Differential, Peerless 100-008A - Tecumseh 794347 : Farmers Exchange
  9. David D.
    David D. New Member
    Sep 12, 2010
    146
    really appreciate the help here, now what would you suggest? if there is a better way i am interested...
  10. David D.
    David D. New Member
    Sep 12, 2010
    146
    yea i see the peerless differental , no specs though, how wide was yours? is it an actual differental with spyder gears and such , or just a friction clutch to allow slippage?
  11. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    Hook Up #1 Surrey To #4 Trailer!
    If you're building a fleet of motorized surreys, costs of parts, labor and maintenance would be compounded. Each powerplant would be vehicle-specific.
    I got me a BRILLIANT plan!!dance1
    PUSH TRAILERS!!!
    Rig up each surrey to accept the same push trailer.
    Build all your push trailers EXACTLY the same. No CVT drive necessary, since parade speed is crawling speed. Concentrate on low-end torque and dependability/reliability.
    You could have six surreys and four push trailers. If surrey #1 has a last-minute breakdown 30 minutes before the parade, simply unhitch its push trailer and hook it up to another surrey. If the engine or push trailer develops problems an hour before parade time, simply replace the entire push trailer.
    Thoughts?
  12. msrfan
    Sep 17, 2010
    1,779
    36
    They come in many configurations and can be modified depending on your tools. Need to look through a Techumseh Peerless catalog. Mine has about a 30'' track. Northern Tool offers one also. Just a thought, but you could mount the wheels right onto the ends of the axle along with the pedal drive sprockets and the motor drive sprocket. Add a disc brake kit like on a go-kart and no need for any other brakes. I also like the push trailer idea but pushing around turns may be cumbersome, along with the added overall length.
  13. msrfan
    Sep 17, 2010
    1,779
    36
    Also a centrifugal clutch at the engine would allow pedal power with the engine on or off.
  14. David D.
    David D. New Member
    Sep 12, 2010
    146
    sounds like a great idea to me 5-7... will mention that to the owner, have a feeling he wants engines ON his surreys though, might be a hard sell...then again maybe not.... hey... I WANT to put engines on his surreys....weld
  15. 5-7HEAVEN
    Aug 2, 2008
    2,364
    Thanks, David.
    Try this display of simplicity:
    Line up his fleet, side by side. Have him sit in a surrey. Stand behind that surrey. Explain to him that YOU are the "push trailer". Now push the surrey a few feet ahead.
    Now he gets out and sits in the next surrey. Stand behind it, then push him a few feet forward.
    He'll get the idea how simple, independent and versatile a push trailer will be.
    Work smarter, not harder. :)
    LOL, I KNOW you want to modify each surrey, I would, too.
    But I wouldn't wanna maintain each vehicle-specific drive system, lol.
    "Engine trouble, sir? Okay, let's unhitch it, hook up another trailer and off you go. In the meantime, you can utilize your surrey and I'll work on the ailing push trailer. See you in a few days".
  16. David D.
    David D. New Member
    Sep 12, 2010
    146
    but what about all his buddies?
  17. David D.
    David D. New Member
    Sep 12, 2010
    146
    they wont be bringing me surreys either, if they can just borrow a trailer from my customer.... there could be 20 surreys involved, but only a need for a few of them on any given night.... yea...guess the right thing to do is try and sell him a trailer.... honesty sucks sometimes huh?.....trlrl.
  18. 5-7HEAVEN
    Aug 2, 2008
    2,364
    You never know, David. He might NOT want a push trailer and have engines in each surrey, like you mentioned..trlrl.
    Hey, give the customer what he want, if it's one inside each of them!
  19. David D.
    David D. New Member
    Sep 12, 2010
    146
    well i think i'll tell him about trailers... give him the option... i'll tell him how easy they are to steal... and how if one comes loose it become a runaway killer at full speed and with all those innocent old ladies and children in the crowd...well who knows what might happen.... but hey its your choice.... want to put trailers on here ? no problem .... :) :) :)
  20. 5-7HEAVEN
    Aug 2, 2008
    2,364
    Good luck on the surrey project, Dave.
    You too, Dan!
