Doomracing
want to put a harbour freight predictor 212cc on a cruiser frame. I want to use a snowmobile type transition onit. question is will I need a wide crank setup or will a wide crank still hit the trans case?
Will a trans for a 4 stroke work with this motor. I think it has a 1" (just looked it's a 3/4" output shaft) output shaft on it so I'm not sure if a bikeberry.com 4 stroke trans will fit the 212cc motor, or even blow up from the bigger motor.
All help appreciated
