Yeah, a 28T would net you 31 MPH @6000 RPM, so it would be do-able. This really looks great. The tensioner is genius- it'll be a LOT harder for that thing to ever rotate into the spokes, God Forbid.So far the most difficult part is the chain and sprockets clearance. With a small frame there’s not a lot of options. I used a 32 tooth rear and if I did it again I would get a 28 just to get a little more room for routing.
Nice ideaGot all the cables hooked up and routed. Here’s a little neatness clue, if you are careful you can put the end of the clutch cable inside the return spring and clean up the end of that cable. View attachment 107783
CongratsPretty much finished. Need to make a support for the bottom of the muffler and tomorrow I will start it up.
