Quintin
about a year ago, i built a 2 stroke 49cc kit. ran excellent, no problems. at least until the engine seized. bought a new engine last week (80cc), installed it, got it running, but it doesn't run well at all. the only thing that has changed is the engine. when i rotate the idle needle on the side of the carburetor, literally nothing happens. I've thoroughly cleaned the carb, no change. when i pull the clutch in, most of the time it will stall. the rest of the time when i pull the clutch in it'll idle at low rpms (and moving the idle needle does nothing). also, when i open the throttle, the engine will pick up to about 15 mph (very slowly). my old engine never had this issue, and even when it was brand new it responded excellent and picked up speed very well. I'm not too sure what the issue is. any suggestions?
