So what happens when you have a day off, bored and a few random bikes and parts laying? You see what fits!
I bought the Elgin frame a few weeks ago for $30. Since there were very few parts left on it, I've decided to go with a "vintage" style build with modern components.
I had my Giant STP2 dirt jumper sitting in the corner collecting dust. I figured the fork would look great on this frame, so after a little cleaning out of the head tube, it slid right in! I need to sort the bearings out, as well as add another shim. This fork will allow me to run either V brake setup or disc. Disc will be in the build at later date. I also plan to cut the internal springs and tubes on the fork to lower it down a bit in order to level the stance out.
I started a mock-up of the tank as well. I need to pull the template apart and do some measuring to produce the more accurate final schematic for sheet metal.
Unfortunately, I'm gonna ditch the skip-tooth setup as well. Just too costly to replace the chain and rear cog, especially if it's not going to be a restoration peddle bike.
I'm also torn on the finishing department. I'm not sure I'm really into the whole "ratty" patina thing anymore. I'd like to make it be lean, clean and mean. Thinking about an Army grey-green.
Stay tuned for more as the build goes along! Looks like the Cranbrook build may go to the wife! She loves that bike anyways! Guess I should finish it first!
