1912 Howard & Sons
Sgt. Howard
186
58
28
69
Okanogan, WA
… once you get rid of the kit mount... THAT is fitted 1/4" flat boilerplate, soon to be trimmed & welded into place, once I figure out the mounting holes. Notice the cut-out for the forward gear.
  • Like
Reactions: fasteddy
Velodrome
2,387
271
Phoenix-ish
AAAHHH That's better! It will sound a bit more authentic as well. Thats a nice build you got going on there. Loose that muffler box and you gain a bunch of room.
  • Like
Reactions: fasteddy
indian22
4,722
7,697
Oklahoma
Top & bottom to answer your question.
From a welders perspective the tube is really thin and the plate quite thick so it's a bit tricky to weld without blowing holes in the tube. If you bevel the two notches in the plate to a knife edge (top & bottom) & weld both sides, top and bottom in two passes, each side (top & bottom), while directing the great majority of the heat towards the thick plate; you will avoid burn through on the tubes while still adequately penetrating the thick plate.
Tig would be the best for this, but Mig is ok also on gas. Flux can be a real challenge for home welder's on operations of this type.
Rick C.
  • Like
Reactions: fasteddy
Sgt. Howard
186
58
28
69
Okanogan, WA
Rick C.
- thankee much- I am working with a gas 'pony' rig, so that's good to know.
