1911 Flying Merkel single build.
OK. Here we go. Assembled polished and ready for a test fit to make the motor mount
Nicely done. The 3 D clutch looks right at home with the vintage look. I've got one waiting for mounting on a 212 Predator for an upcoming build & your engine is inspiring me. Rick C.
Alrighty then, Last week and early this week the stars alinged and I was able to work on the bike WITH Bob available to weld!!! Got stuff done! First I cut the old cycle-truck stand I'm using for a dropdown stand WAY too short! Nothing like making work for yourself. Once that was fix'd I box'd in the sides and put hidden shoulder bolts in pre determined hidden spots with drilled access holes for screw'n and un-screw'n Also put some bolt heads on the forks to limit travel and keep the bars out of the gas tank.
I like the heavy duty stand you've put together & it's functional insurance that looks good as well and will keep your bike looking good by preventing tip overs. Rick C.
Looking at the way the stand was constructed for strength and also so degree of light weight as it is hollow if I see right, was very ingenious.
I made for attachment, no don't laugh..... training wheels. Well for parade speed with bike covering in detail art work of a fish shape. Don't want to fall over and damage me or the covering or the bike.
Currently it is very strong with covers over the carb and the tranny. No damage even when leaned up against a picnic table, it rolled just enough and fell onto a fire ring near by. Nothing to show damage.
The ground in the OHV trail area was just to uneven for my center stand. Some times I use wood chucks to shim.
The axle was too short to put the brackets I made of strong metal tubing and channel steel directly on.
I welded gussets by the drop out and then extended like a second drop out aft. It flexed too much.
I just got light bulb going off now.
I tried to get a longer axle and found one in the past just a bit longer for my wider belt sheave when I installed it.
If only I could find an axle longer that would work that is necessary.
One other way I can see about attaching some metal right close to the slots in the drop outs, connect this to the metal already welded in the gusset area of the drop out just a bit forward, then it should not flex.
This is I see as what has been done welded to your drop outs just aft of where the axle fits with the premade parts. Those things for the bolt to go attaching your back wheel stand.
I just some how forgot that when the axle is bolted in the drop outs at that location, it is like the connection that makes a truss. Gussets on the drop out are they necessary for maybe higher engine power. While you have a welder doing stuff? Neat they have those prefab parts to weld on for the rear stand.
Back to your bike, that engine is some real looker! The external push rods will they more or are they faux?
Nice Idea on the trainers for the art bike. Yes; I had to shift the rotation point well aft of the dropout ends for the stand to not interfere with the axle nuts when in the up position. Hollow but strong like bull. Rods are just for looks. That, and the extra fins and flathead look'n bits from Dan at Taylar Motorbikes.
I was thinking now I can try what I said, or move the attachment point to under the foot pegs for the extra small 10 inch tires.
I went back and looked at the pictures of this build you doing. The drop outs you have right where the axle nuts tighten on are nice and robust. Thick. From this old frame I have save from trash it is far from that. I could get some metal and redo those with the wear and tear through the ages.
Is it looking like you are nearing finishing this bike your building. I seem to for get if you build multiple bikes at once. Many on the forum have that going. Anyway I took probably 3 years and then got lots of bugs out after a couple more years, but just the one bike.
Congrats on a cracking looking boardie, Velo. Your take on the unique Merkel tank is outstanding and those back-dated motor mods look right at home on this build. Should look killer once painted in trad orange livery.
Thanks! I got next to nothing done today other than keeping an eye on my elderly ( very ) mother. I did make a trip to the hardware store for some fittings though. Just wouldnt be right going through the day without a trip to ACE Hardware!!
Looks great... and looking at the length of that pipe .... must of came from a adopted family member! Bikes awsome!
Papa was a roll'n stone... These shots were actually done bout 2 weeks ago. Had a nasty injury to my L ankle with a bad following infection. But prior to that I got the thing running and starting with just pedal starting! Rides great but I need a modern camera to post a video and no way I can ride or even work on it just now. And yes; its LOUD!
