Next-avalon friction drive 31cc
Ibedayank
just a sub $500 dollar build to have some fun riding
start with the bike
attachment.php
add 31cc friction drive kit
attachment.php
grind brackets so mount clears tire
with motor mounted
mount to carry gas... it needs it
buy new tires to replace the crappy stock tires....
rear won't fit have to rebuild rear mount
now it won't come out of alignment again
still need to make dual rear struts for rear motor mount
make mounts for 64 ounce tank
take bike apart and cleanup mount and repaint
for the $$$ its a nice little kit and a good match for the bikes 7speeds
in 7th gear you max out pedaling candance as the motor really starts to sing
I also like the idea of rear suspension. The best I can do is get a spring loaded seat post. You have real suspension.
it does a good job smoothing out the bumps on a paved road but would not take it offroad. The bicycle really is not built that heavy.
Noice build! An engine is just a compressor with spark, the more air flows through the more power you get, especially with a thumper.
I'm running the same kit, and I noticed the power drop too. I thought it might improve once the engine broke in more.
Maybe carb jetting, or better intake flow? Maybe a less restrictive exhaust?
DRC
have you noticed a ""sweetspot"" where the motor gets quiter but has more power?
It seems to be between 1/2 to 3/4 throttle. Then it roars and slows. Roll off the throttle, and it takes off again.
At first, I thought the FD roller was slipping on the tire, but I found out it wasn't.
Then I was thinking clutch slippage.
I was just going to wait for a few miles to see if it needed a better break-in. Then I was going to experiment with intake and exhaust.
I'm aware that it will never be a speed demon, but I don't think it's even going 20 mph right now.
I have about 30 miles on mine at this point and did change to a staton 7/8s roller and new bearings as the ones that came with the kit had a gritty feeling when you spun the roller. I have been unable to find specs on this Chonda motor but the motor its based on I did find the setting for valvelash for the honda 33cc
spark plug gap .024-.028
idlespeed 3100 +- 200 rpm
valve clearance COLD IN. o.08mm +- .02
EX 0.11mm +- .02
oil 10/30 in temps 90f and above 30 weight
spark plug NGK cm5h or cmr5h
hope this info helps others with this kit
That is a typical symptom of a too lean air/ fuel ratio. Reduce the incoming volume of air by reducing the throttle position to a point where the fuel delivery can match it and you get power again.
