Next-avalon friction drive 31cc
296
Tyler Texas
I'm running the same kit, and I noticed the power drop too. I thought it might improve once the engine broke in more.
Maybe carb jetting, or better intake flow? Maybe a less restrictive exhaust?
Sep 18, 2011
296
Tyler Texas
DRC
have you noticed a ""sweetspot"" where the motor gets quiter but has more power?
It seems to be between 1/2 to 3/4 throttle. Then it roars and slows. Roll off the throttle, and it takes off again.
At first, I thought the FD roller was slipping on the tire, but I found out it wasn't.
Then I was thinking clutch slippage.
I was just going to wait for a few miles to see if it needed a better break-in. Then I was going to experiment with intake and exhaust.
I'm aware that it will never be a speed demon, but I don't think it's even going 20 mph right now.
Ibedayank
1,171
Columbia Tennessee
I have about 30 miles on mine at this point and did change to a staton 7/8s roller and new bearings as the ones that came with the kit had a gritty feeling when you spun the roller. I have been unable to find specs on this Chonda motor but the motor its based on I did find the setting for valvelash for the honda 33cc
spark plug gap .024-.028
idlespeed 3100 +- 200 rpm
valve clearance COLD IN. o.08mm +- .02
EX 0.11mm +- .02
oil 10/30 in temps 90f and above 30 weight
spark plug NGK cm5h or cmr5h
hope this info helps others with this kit
