Foil? No, way too flimsy but cutting one out of aluminum sheet would work well.Would using a sheet of aluminum foil to make an exhaust gasket work? Haven't tried but was woundering if it would or could work....
SBP said:Exhaust Gasket only $2.49
Aluminum exhaust gasket. Much heavier duty than the stock replacement gasket. Can be used with any exhaust system and is easily hand machined to match any exhaust set-up. Soft aluminum makes a great seal and matches the metallurgy of the engine. Supplied with all our expansion chambers.
LOLyeah, just a thought/idea that popped in my head randomly.
The broke cheapskate guys here usually talk about using cereal boxes as gaskets, lolyeah, my surfaces are good and smooth. I'm experimenting with anything that may work.
your idea is much better....
I made one. Heavy duty aluminium foil, fold it over like 20 times, stick your exhaust against it to mark out your lines, get a sharp cutting tools, cut out the holes, get aluminum paint cover gasket with it, then slap it on. Worked great.
